Oversized valves for XU10J4RS
Hi, anyone with experience with oversized valves on XU10J4RS?? I bought Sinus Performance from SPOOX (+1mm). But when I measured weight of them I found they have about 56g instead OEM 48g. How much matter weight of them?
Other components:
- Wossner pistons (86mm) high compression
- Catcams H-beam rods
- Sinus Performance Valves (35mm + 31.7mm .... original has 34.1mm + 30.8mm) www
- Camshaft Piper 264deg www
- Valve springs - Piper www
So please any opinion?? Thank you very much.
bigger valves are a waste of money, as are the springs for only that much camshaft, and the pistons and rods are not great quality, though the 285H cam has too much lift at TDC for the original piston, still borderline with +1mm deeper cutout.
  Sluggish xu10j4rs sherman306 19 10,544 23-06-2014, 05:17 PM
Last Post: Niall
  XU10J4RS Idle AFR jammapic 8 6,122 14-10-2013, 12:24 PM
Last Post: jammapic
  The XU10J4RS Manual Scott 5 9,946 29-12-2011, 10:21 AM
Last Post: Scott
