Powerflex
Right my bottom engine mount is absolutely fooked! It's actually almost impossible to change gear without it clunking about.
I was going to get a spare mount and press a standard bush in but then I thought that it would be an ideal opportunity to upgrade! I don't want to go mad and get a group N mount. I know there great but it's a daily.....sort of....and I would like to keep vibrations to a minimum.
What's the powerflex bottom bushes like for this?
Im in the same boat as you, not bought one yet, vibrations on yours wont be that bad I would have thought, now mine is diesel, could be bad, mainly at idle... I have heard that you can drill some large-ish holes in the powerflex bushes to soften them up abit if its too bad...
MTFU and get a BBM one! /thread
Ed Doe Wrote:MTFU and get a BBM one! /thread
Unlike you ed it matters if vibrations transfer through the cabin of my car. You could have solid metal mounts and it won't matter because your engine is separate from your car!
[img]http://3.bp.blogspot.com/-THAexJyqA3w/TmVLMj1rdcI/AAAAAAAAISs/OmXgO7T63qU/s1600/Oh+no+you+di+int.jpg[/img[
And admittedly I hadn't fitted the bottom one, but the upper 2 were bbms, and they were faptastic....
Dont get a powerlex one, i changed my lower one for one and they arent as good as they should be, its getting ditched for a BBM one asap!
Iv heard the powerflex ones arnt very good. I should have my BBM fitted saturday. I will let you no itlf they are really that bad for vibs
BBM or a standard mount rotated 90*
[Image: sig.jpg]
  Powerflex 306 Front wishbone kit thiscocks 37 19,344 07-07-2014, 12:47 PM
Last Post: thiscocks
  Powerflex wishbone bushes...Email from Powerflex! Piggy 87 49,751 05-04-2014, 09:53 AM
Last Post: pug306driver
  Powerflex wishbones titch 6 3,722 10-07-2013, 08:51 PM
Last Post: titch
