strut top mount + seats
Hello all,
I'm after the metal part of the strut top mount assembly (don't think they are sided are they?) It's the NS I need though, ever since the spring snapped that side and replacing it including new rubber strut mount the metal part fouls on the strut tower, assume the force of the spring snap has damaged the metal part! Was enough force to trigger the red button.
Also looking for seats, either a complete set of half leather/full leather, or just front seats in the leaf design in good condition if that's even possible!
Thanks, Ali
I should be able to sort you out a spring cup. Ill try and dig one out my spares this week.
sounds like its not seated on the bearing properly, I've not seen a damaged top spring pan before, springs tend to snap at the bottom anyway!
100% in correctly, I spent a day in April thinking I was bat shit crazy took it in and out about 4 times. Even took the other side out and swapped bits over and to compare. Weird!
bend it back with a hammer!
  Black and Blue Cloth Seats HDi DTurbo Seats? RadiationBeta 1 2,489 10-09-2012, 09:54 AM
Last Post: puglove
