**wanted** arp head studs
On the quest for arp headstuds for either dw10 or xud9. If any ine has a set ready with machined spacers to suit hdi spot on!
Cash waiting!
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Can buy direct fit ones from ARP if you work it out
(07-10-2017, 05:28 PM)Piggy Wrote: Can buy direct fit ones from ARP if you work it out
Struggerling to work it out Sad got the originals worked out but dunno if they can work with those figures. Did contact them early last week
Justin_306DTurbo
You don't need to contact them..... Just get ya head in some basic math and a straight rule. Plus a pad
Do i need to add on aditional lentgh tho for the nuts?
And will i require the washers
Justin_306DTurbo
I could possibly also be interested in some if you find out any more info justin.
(07-10-2017, 05:59 PM)dr_jekyll Wrote: Do i need to add on aditional lentgh tho for the nuts?
(07-10-2017, 06:26 PM)Frosty Wrote: I could possibly also be interested in some if you find out any more info justin.
i'm going to be ordering some sets - can add you both in if you want
drop me a msg here or FB
I would deffinatley be up for that!
Found a company under the following web address that provide kits for xud9 https://www.dp-engineering.nl
Ive contacted them frosty in hope they can provide us with a direct fitting kit for our dw10.
What ive managed to find out so far is the fitment of an xud9 is m12x1.5 148mm long vs dw10 thats m12x1.5 130.5mm long.
Unsure what the nominal lentgh of an xud arp is so atm ive emailed the company and asked them if they can supply an arp headstud 18mm shorter then the xud9 one they list.
Worst case scenario is we have to buy xud9 ones and machine spacers.
Justin_306DTurbo
well lemme know, i'll be sorting it early next week.
dp engineering used to do a set, can't remember if they used arp studs though or just custom studs with arp nuts - used to work out expensive with them after adding tax and delivery.
Ok cheers tom, will let you know as soon as i know. Ideally be nice to have direct fit ones to save having to sort out and use spacers.
Im a deffinate yes and have money waiting.
As said if the company your using tom can supply the xud9 ones and some the same spec but 18mm shorter it would be even better for dw10 guys
Justin_306DTurbo
know one on this forum willing to hand out the part numbers?
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
(08-10-2017, 03:43 PM)Stef205 Wrote: know one on this forum willing to hand out the part numbers?
Apparently not
Justin_306DTurbo
I can't remember them off hand..... But if people weren't lazy, had a ruler and a stock bolt.... It wouldn't take long to work it out. All the info you need is out there. Don't even need a stock bolt tbh...can find the lengths online.
(08-10-2017, 07:21 PM)zx_volcane Wrote: 8008135
Rofl
Checked the codes out tom that we were given and they do check out.just one more thing left to double check fitment
Justin_306DTurbo
Rofl
code checks out OK for me!  whistle
 | Y |
GTI6 Info
Rofl
 | Y |
Wasnt refering to that but did take me a while [emoji23]
Justin_306DTurbo
  FOR SALE: SOLD - £170 - XUD ARP Head Studs silverzx 3 2,858 06-11-2015, 11:59 AM
Last Post: silverzx
  FOR SALE: ARP head bolts/studs Piggy 8 4,684 07-07-2015, 01:18 PM
Last Post: Piggy
  GT2052 set up £75 and arp head studs Chris_90 10 8,890 05-12-2014, 10:22 PM
Last Post: Chris_90
