Upper Steering Column
There's play in the upper steering column on both of the cars I have on the road. It's not really bad yet but a bit annoying.
Have read this thread on the GTi6 forum so may try fitting new top bearings. http://www.306gti6.com/forum/showthread.php?id=166359
Failing that, anyone know where I could source one that's not going to break the bank? Peugeot ones cost a fortune!
I was taking a guess at what to buy so no idea if the one in the link will work just seems the dimensions seem correct. I imagine the needle bearings will be a bugger to fit. I broke the bearing cage removing it.
Ahh, it was your thread!! Thanks for letting me know. Definitely not so straightforward then.  Dodgy  I did also wonder how you would deal with any wear on the surfaces the bearings run on. At some point I might get hold of a column from a breakers n strip it down to make my own assessment of what can be done. Will post up here if I ever do.
  Top steering column bearings up for grabs vinny 1 2,633 08-01-2020, 03:55 PM
Last Post: Mighty306
  Nackered steering column? Tom 0 1,883 20-05-2013, 03:44 PM
Last Post: Tom
  Steering column compatibility martyn92 0 2,031 22-04-2013, 05:07 PM
Last Post: martyn92
