Threads: 24
0
Ecu temp sensor is worth swapping. Green sensor on thermostat housing best to fit genuine as most pattern ones aren't much good.
Threads: 448
51
That something that would affect the fueling that much?
It's also having an occasional starting issue where it will just turn over for ages unless it's left 30 seconds or so. Doesn't happen every startup just the occasional. Could be related?
Friend has a code reader so going to stick that on at the weekend and see if anything pops up
Threads: 448
51
Yep it's god awful, I thought there might be more idea in the issue, but threads rather quiet haha
Threads: 24
0
I would change ecu temp sensor and check fuel pump relay ( i had them cause over fuelling too )
Threads: 162
21
Car Model/Spec: 306 HDI Dturbo, Estate & GTI6
10-10-2017, 09:25 PM
(This post was last modified: 10-10-2017, 09:26 PM by DeeTurbo.)
Might be worth checking for a fuel leak, the elbow near the filler are known to leak.
Also worth checking for brakes binding if it's been standing. Sliders or pistons might be getting stuck.
Does the exhaust smell rich after a run?
Threads: 448
51
Okay so I'm gaining mpg back, but I have changed nothing so far. Been trying to source any leaks before I buy parts. But I can't see any visible, I'm wondering if there is a hole in the line somewhere that only sorays when it's running
Threads: 9
Car Model/Spec: Ph2 GTi6 track, Ph3 GTi6 road
I've had mine leak from connectors to the lines direct to/from the fuel rail. Couldn't notice with the engine running but if you stopped it running the fuel would slowly seep out at the connection. Plus as mentioned rear elbow.... only leaked if I parked the car backwards on the drive (hill). The top of the pipe was cracked so didn't leak on the flat, but was enough for the fuel to evaporate off. Does the car smell of fuel?
