For Sale: 2000/X E46 330 Ci
For sale: 2000/X BMW 330 Ci
Price: £2100 ono
Mileage: 142k
5 speed manual
MOT: 12 Months
Tax: Currently SORN
Last serviced: 136k
BMW history to 70k then independent to 100k. Then maintained by previous owner then myself to present. Loads of receipts etc..
Just bought an E92, genuine reason for sale
Drives nice has had most bushes replaced. Body is pretty clean in general but it is 17 years old, I've pictured most of it. Has 2 keys, grey leather interior, electric memory seats. Cruise control, climate control.
In my ownership (4 years) its had the following:
New expansion tank with new coolant
New waterpump and thermostat + thermostat assembly
New alternator
New AC tensioner
New belts
New hedgehog resistor
New power steering hoses + fluid
New VANOS seals including gaskets etc.
New rocker cover gasket set
New CCV and associated pipework
New spark plugs
New fuel filter
HEL Braided front brakes lines, w/ new hard line on passenger front. New fluid, have rear braided hoses just not fitted will be included
New front wings
New front discs and pads
New oil filter housing gasket
New cabin filter
New front wishbones
New poly lollipop bushes
New inner and outer track rod ends
Hunter wheel alignment
Solid billet steering bush upgrade
New upper rear trailing arm bushes
New poly RTAB bushes
HSD Monopro adjustable coilovers, had new rear shock bushes recently
Adjustable drop links
LED rear lights
Pressed plates w/ BM surrounds
M sport rear bumper and side skirts (I do have an Msport front bumper too, didn't get around to painting it)
Stereo ISO harness conversion for regular head units, can include oem head unit and changer
M3 xenons, also have original halogens
New battery
E92 alloys (style 189) with bridgestone potenza runflats, decent tread
Bad points, most pictured:
slightly sticky lifter, ticks for a second or so on cold start (always done this)
bubbling on passenger rear arch
rust in bottom of passenger side door.
dent above door handle on passenger side
small scuff on edge of rear bumper
Steering wheel worn, few degrees off centre (from fitting solid steering bush)
Stonechips on front end, grill bumper etc..
Oil level sensor not functioning (occasional light on dash)
Rear diff bush knocks, have a powerflex bush just not fitted yet will include
Subframe bushes, rear brake lines - advised on MOT but won't need doing for a fair while
[Image: MaV1fUU.jpg]
[Image: QIuusy9.jpg]
Link to full album (including pics of bad points): https://imgur.com/a/vVL9p
I'm based in Weston, PM me if you want any more info
  2000 306 cab China blue for sale addscalamity 2 4,201 19-09-2018, 10:28 AM
Last Post: ianwedderburn
