03-01-2018, 01:28 PM
I am doing the bearing (on the right side this time lol) and want to replace the two pinch bolts. Does anybody know the sizes needed? I will be using 12.9 cap heads so need the length of the plain shank too. ?
Ball joint/ Hub to strut pinch bolts
03-01-2018, 06:25 PM
Check ebay. They do them. Brand new in pairs.
03-01-2018, 06:31 PM
theyre extortionate on ebay.
55mm long but longer shank than an sae fastener.
03-01-2018, 07:15 PM
Cheers geezers. Further research has come up with-
BJ pinch bolt-M10x55 with a 20mm shank. Strut Pinch bolt-M10x65 with a ..... shank. Will update when I find out more.
03-01-2018, 09:43 PM
(03-01-2018, 06:31 PM)welshpug Wrote: theyre extortionate on ebay. Iirc I paid £3.50 Inc postage for a pair. I was happy with that Wishes for more power...
03-01-2018, 10:09 PM
Servicebox lists the BJ pinch bolts as M10 x 50mm (for HDi estate). Also 50 on the XSi (18mm BJ's) & they're plenty long enough - replaced them recently.
Strut pinch bolts listed as 65mm length.
04-01-2018, 07:06 AM
04-01-2018, 11:40 AM
If you want a smaller qty and to upgrade to 10.9's this site is pretty good. Have ordered quite a bit from them now without any issues. Also, if you need anything in fine or extra fine thread, it's worth giving them a bell as they can supply stuff not listed on the site.
https://www.westfieldfasteners.co.uk/BZP...Rpart.html This site is pretty good too. https://shop4fasteners.co.uk/hexagon-10-...olour.html |
fitting a front suspension ball joint | impotentials | 3 | 2,022 |
29-10-2016, 05:46 PM Last Post: Poodle |
Bottom ball joint sizes | Xsikid | 4 | 1,644 |
04-05-2016, 05:45 AM Last Post: Paul_13 |
hub pinch bolt spec | rd070707 | 4 | 1,731 |
22-02-2014, 07:49 PM Last Post: swampy |
