Threads: 48
4
Car Model/Spec: 306 Rallye
05-09-2017, 07:37 PM
(This post was last modified: 11-09-2017, 08:17 PM by Ben_w.)
Last few bits off this 6 before i pull the engine and scrap the shell....no reasonable offer refused as they will go with the car if still here.....can post all of this lot too. Most will only cost a couple of pounds to post. Heavier/glass bits perhaps a little more
Front wing trim bits (both) - £5
Passenger side rear light - £5
Seatbelts (both) - sold
Front end loom (not including engine loom) - pending
Fuel door and dummy fuel door - £10
Wiper arms with good Bosch blades - £10
Opening rear quarter windows - £10 each
Washer bottle and pump - pending
TA Technix coilovers - £60
Rear beam - sold
ABS Pump - £10
Wiper motor and linkage - sold
Threads: 48
4
10-09-2017, 09:19 PM
(This post was last modified: 14-09-2017, 07:30 AM by Ben_w.)
Last few remaining bits from this 6. Be available for a week until the shell gets scrapped. If any of its still here then, it goes with the shell. Car was a 98 R phase 2.
Entire front end loom (minus engine loom) Pending
Steering rack Pending
Std shocks and -40mm springs Pending
TA Technix coilovers Sold
Fuel filler neck £5
Heat shields £5
3 arch liners (2 rear, one front) Pending
Bitron unit Sold
Rear light £5
Good clutch cable £10
Wiper motor Sold
Washer bottle Sold
Twin fan unit Sold
Airbag ECUs £10
Threads: 10
Given 1 thank(s) in 1 post(s)
11-09-2017, 06:15 AM
(This post was last modified: 11-09-2017, 06:18 AM by paulgtt.)
Hi Ben,
I will take the std shocks with lowering springs and possibly the arch liners and wiring loom.
Could I collect one evening in the week or at the weekend?
Threads: 48
4
Paul, yes, that's fine. Friday night or the weekend as I'm out Tues, weds and Thurs.
Threads: 10
That's fine can you text me your address and we'll sort it out, 07790 457159. Thanks
Threads: 101
2
Car Model/Spec: 306HDi 90 LX
is the screenwash bottle standard on all models?
if so, can I request it and the bonnet blanket.
please pm total inc. postage.
It goes, it stops (as reqd).
Hate Housework!
Threads: 52
4
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
I'll take the wiper motor off you Ben. I guess it's quite heavy so does £10 including shipping seem fair?
Sorry if you've already posted the fan relay cover as otherwise you could package them together.
Cheers,
James
Threads: 48
4
(11-09-2017, 06:19 PM)Mighty306 Wrote: I'll take the wiper motor off you Ben. I guess it's quite heavy so does £10 including shipping seem fair?
Cheers,
James
Sent you a message James
Threads: 48
4
(11-09-2017, 04:08 PM)Magenta Sunset Wrote: is the screenwash bottle standard on all models?
I think it is bud. Can't see any reason why it would be different on the 6. Had a twin outlet pump for the rear washer which I assume all 306's had.
Threads: 48
4
Right, last few bits to go...
Fuel filler neck £5
Heat shields £5
Rear light £5
Airbag ECUs £10
Wing mirrors £15 (both)
Threads: 48
4
Still got the wing mirrors and the front end loom if anyone is interested?
