Is thickness of radiator important?
I bought a nissens radiator for my 97 dturbo, but in the box I got an ordonez. I thought maybe they're just an oem for nissens, but it was also thinner than the specifications so I bought the same part number from a different source to be sure.
This second one turned out to be nissens branded and the right thickness - but it was also a bit more expensive so I'm not sure which one to keep (both are easily returnable).
Is it possible the ordonez one is a newer design that cools just as well with less material?  The thicker one certainly came in a much older looking box.
Also I really wanted a drain plug to make life easier in the future; the ordonez doesn't have one, and the nissens has this weird bit where one should be, but I can't work out if I can make it into one. Annoying cos the spec for this nissens part says it has a proper one
[Image: y4m__lwxHNtoU6xhWBa_8rgfMHDrD-JSPcLi-SL-...pmode=none]
[Image: s!AnOsE9t_J3F3gtVio8zvkXkZlpCyIA]
thicker is better for sure
only if it's efficient.
(16-07-2017, 09:52 AM)welshpug Wrote: only if it's efficient.
id put money on the thicker nissens being better over the thinner ordonez one
(16-07-2017, 07:50 AM)zx_volcane Wrote: thicker is better
They're both made of aluminium, have the same size and number of pipes, and the same fin spacing, so I guess the only difference related to cooling is a bit more fin surface area on the thicker one. Unless there's any other way a radiator can be made more efficient?
Regarding where the drain plug should be, I've realised pug sells them separately - does anyone know if one would fit in there (130677)? Although I guess I'd have to drill a hole for it to work, which doesn't seem like the kind of thing you'd normally have to do..
My Nissans has a drain hole
Non of my nissens rads had drains
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(17-07-2017, 08:13 PM)HDIkyle Wrote: Non of my nissens rads had drains
you sure? . . . .  you need a big wide flathead to open it Smile
I can confirm my last nissens one also had a drain as matt said
Did it look like this:
[Image: IMG_0567.jpg]
[Image: IMG_0568.jpg]
If so, do you have to make a hole for the coolant to come out?  Or did they come with a drain plug already attacged?  Huh
  headgasket thickness Ricky 5 4,018 23-08-2012, 12:08 PM
Last Post: Ricky
