Front ARB Bushes
Front ARB Bushes
Hello all I am currently fitting new Front arms to my GTI-6 whilst doing this I thought about replacing the ARB Bushes as they are 17 years old and done 114k.
Is it worth it as I have seen threads they are poly from Factory also are they a pain to change over do you require any grease etc?
Im sure a bit of grease wouldnt hurt. I havent really heard of anyone replacing theirs. Should be fairly easy to do.
Had mine replaced at 165k miles, and they were still fine, definately worth doing to freshen up the front end though.
(28-06-2017, 11:56 AM)MY95 Wrote: Had mine replaced at 165k miles, and they were still fine, definately worth doing to freshen up the front end though.
notice any difference at all?
Hard to tell Sam, had the full front end suspension replaced at the same time, but probably.
I replaced mine. The old ones barely looked worn.
I wouldn't bother as it is very fiddly, and they are indeed poly from factory.
62k Diablo Phase 1 Gti-6:
Project Thread
Thanks for the input guys I have had a look and they don't look great Lemforder ones are cheap enough so whilst I have the arms off I will change these out to. Any tips for removing them I see they fit in a specific position.
Removing them is ok, once the droplinks are disconnected you can wiggle the ARB a lot. Refitting them is tricky, the brackets holding them down bolt down to the subframe through the p-bush as I am sure you can see.
The rear of the bracket just has a hook on it. It is difficult to get this hook in, and then pull the front down enough to get it through the bolt.
With the subframe off I imagine it is easy to build it all up and then put the whole assembly on the car. With it fitted the clearance isn't great. It is possible, just a PITA, but then I never was good at fiddly things!
Project Thread
Thanks for the info im sure I will have fun with this over the weekend.
Well new ARB Bushes fitted very fiddly but with patience they are not too bad. The drivers side one was knackered passenger side still stiff.
  Powerflex Front Wishbone Bushes gti6man 2 2,088 16-11-2017, 09:36 PM
Last Post: miles
Rainbow Front arb bushes sizes Welshy_Pete 0 812 22-12-2013, 12:23 AM
Last Post: Welshy_Pete
  Front anti-roll bar bushes Ben 22 6,326 18-09-2012, 05:57 PM
Last Post: puglove
