BE3 Input Shaft Shim
I rebuilt a BE3 box with shafts from a donor box. So an admission of being lazy, I whacked it all together without paying much attention to input shaft shimming. The box has the original shim installed. The input shaft bearings whine considerably which I assume will be due to incorrect shimming. I'm struggling to find any documentation on this, apparently it's in early 205 Haynes manuals? Can anyone offer some quick guidance so I don't need to wait on Haynes manual in the post?
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
in french. hope it'll help you.
.pdf   05a.pdf (Size: 2.54 MB / Downloads: 206)
Thanks! I'll see what I can make of it. I've also paid 7 euros for an hours access to technical documentation on Servicebox, busy braindumping as much as I can to PDF!
