headlights change ph1 into ph2
anyone able to help is it possible to fit ph1 headlights into a ph2 and any help on wiring the connectors would be awsome
not really mate, anything is possible but not seen it done myself Smile
Thanks given by: Kcbhoy111846
yeh you could wire it all up but remember you need the phase 1 bonnet to get the lines right. The wings should be the same.
Phase 2 is a bit harder than phase 3 so you need to work out if youve got twin or single optic headlights and may need to change the stalk if that changes.
first off you will need bumper grill slam panel bonnet
or your car will look like it has a fat lip
GTI6 Info
sounds a bit more complicated than first thought its the wiring thats confusing me just now
(20-04-2017, 08:02 AM)Eeyore Wrote: yeh you could wire it all up but remember you need the phase 1 bonnet to get the lines right. The wings should be the same.
thank you
