Threads: 42
28
all the dt filter boxes ive seen have been steel and just as rusty
Threads: 82
27
One in the link above is plastic, all the other brand new ones ive seen are plastic too
Threads: 132
Given 6 thank(s) in 6 post(s)
Are they not plastic with a metal base?
Threads: 82
27
Possibly, but I can't tell from the picture and it doesn't state. Either way it's a brand new Peugeot item, I've seen them as cheap as £35-38 posted. Currently a rusty GTI6 airbox on ebay is £50 collected albeit it's the only one on there
Threads: 371
29
Car Model/Spec: ford fiesta
The one on lus that i pulled off a scrapper we had. Is all plastic. including bottom
Threads: 82
27
Np, let me know how you get on if you get one, will probably get one myself to try soon
Threads: 90
Ph1 are all metal , Ph2 are plastic... From what I seen anyways.
Threads: 82
27
Assuming they don't make the PH1 boxes any more/they're out of stock now? Don't suppose anyone knows the inlet size for the DT box if they have one lying around? Believe the '6 intake piping is 76mm
