Danny's MK5 Transit.
- 09:32 PM
You know I love Transits, and mechanical injection.  And boost
Mk5 Transit, 68K, one owner electricians van. £150.
I intend to own this van for as long as I need a van.
[Image: post-19867-0-04471200-1486499103.jpg]
[Image: post-19867-0-30856100-1486499185.jpg]
[Image: post-19867-0-67250000-1486499278.jpg]
[Image: post-19867-0-21559600-1486499337.jpg]
[Image: post-19867-0-38094300-1486499452.jpg]
Bear with me, Copying from elsewhere.
[Image: post-19867-0-31150000-1486499609.jpg]
[Image: post-19867-0-42514200-1486499658.jpg]
[Image: post-19867-0-73111000-1486499703.jpg]
[Image: post-19867-0-09287900-1486499767.jpg]
Slight picture taking fail after the trial fit there but more to come soon.
And in case anyone was wondering, I did cut out the inner arch as well.
Most new panels, except the wings, are galvanised. [Image: post-19867-0-17037900-1486501578.jpg]
Lucky escape! Always check above where you are welding kids!
[Image: post-19867-0-85292800-1487707111.jpg]
Yikes! (pic is sideways for some reason?)
Haven't had much time on it recently but some filler, sanding and a bit of primer has occurred.
I'm getting towards needing it done so have to make more time for it.
[Image: post-19867-0-16645500-1487707234.jpg]
That arch is finally done.
Only three more to go.
If I learned anything from doing it, it was to remove as little as possible, without leaving any rust.
I cut away too much and left myself with next to no reference to put it back right. If the inner wings were the same as the old ones I don't think it would have been so hard.
Luck was on my side and it tuned out OK in the end.
[Image: post-19867-0-41753600-1488479470.jpg]
[Image: post-19867-0-98527800-1488479513.jpg]
[Image: post-19867-0-75874700-1488479568.jpg]
Need to drill a hole in the new inner wing panel to attach the bumper and put the drivers seat back in and that side is done on the front.
Opposite side front next.
Working my way up to the back one that is the worst, panels available so shouldn't be too hard.
I hope.
Thought I'd make a start on the back arch on the same side as it doesn't look as bad as the others.
[Image: post-19867-0-24068600-1488815801.jpg]
[Image: post-19867-0-74997700-1488815843.jpg]
Is that a spot of rust I see on the chassis?
Let's give it a tap and clean it up a bit.
[Image: post-19867-0-92332700-1488815957.jpg]
Oh dear, I wasn't expecting that.
[Image: post-19867-0-44371200-1488816026.jpg]
Or that.
No matter, found it now so need to deal with it.
Luckily it's two thinner sections that were not to bad to sort.
[Image: post-19867-0-04432200-1488816226.jpg]
[Image: post-19867-0-43156500-1488816330.jpg]
[Image: post-19867-0-97882800-1488816404.jpg]
That's all for today, plenty more to come.
  • [Image: post-19867-0-32329300-1488816393.jpg]
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Nice to see one of these being saved. I really like the smiley face Transits. I got to drive a couple of rental ones when they were still brand new, it was like a Rolls Royce compared to the poxy Sherpa I drove regularly.
I might be doing a bit of welding on a newer one soon, having the panels makes things soooo much easier Smile
so much rust! Great work though! Inspiring me to get a welder! Big Grin
These engines take a beating!!
Sent from my Nexus 5X using Tapatalk
Rear arch repair panels turned up today. Have a three day weekend as well.
Yes, they do Darren, my last one was on 275,000 odd.
Gonna boost this one, I have an RHF5 in the shed.
Did you run a wastegate on your Td04 set up?
        I Don't Have A 306.
Nope, gate was welded, 40psi at the manifold, took it all day long, even with the inline pump!
(04-04-2017, 07:25 PM)Danny Wideboy Wrote: Is that a spot of rust I see on the chassis?
Or that.
Transit! Big Grin
Doesn't look too bad tbf, fair play for taking it on though. Welding up a transit of any age is no job for the faint-hearted, let alone one that's 20 odd.
Amazed you're taking the welding up on one of those - but to be fair got to be a future classic once all the others turn to dust
Mechanicallu they're tough as anything, awesome roadholding.
(06-04-2017, 09:13 AM)welshpug Wrote: Mechanicallu they're tough as anything, awesome roadholding.
Totally agree with that. As a 19/20 year old lunatic driving one with virtually no weight in it because your doing damp-proofing I thoroughly tested the handling when it finally got up to speed.
This one doesn't look too bad tbh, certainly much better than most Disco's of a similiar age.
Thanks for the comments.
It is not actually that bad, all wheel arches, as standard, have rotted.
Bottoms of the back doors, again, standard.  Front strut tops, normal behaviour.
And the small holes in the chassis.  Not too bad for a 20 year old Transit.
Eleventy times better than my last mk6 was. It'll probably owe me about £700-£800 when it's done, a fair price I think.  ( man hours not included, a la wheeler dealers :-)
        I Don't Have A 306.
Obviously, need new inner rear arches as well.
Was hoping to repair what was rotten but the shapes are too complex so new panels are needed.
No shock really, just more money.
        I Don't Have A 306.
Always had a soft spot for mk5 transits, drive so well! mates got a county 4wd one with a turbo motor fitted Big Grin
Team Cyril
Rear arch done.  Primer only in this pic.
There are more pics but my phone won't play ball right now.
        I Don't Have A 306.
Nice work man.
Cheers dude.
        I Don't Have A 306.
Good work man, definitely a future classic.
gotta love a smiley tranny Smile
Everybody loves a smiley tranny.
I spent a while in Thailand and that is basically the motto over there.
        I Don't Have A 306.
It should be a motto for everyone!
In fact it's a good name for a band, write that down.
I can see it now, "Live on stage tonight, O2 arena London, it's.... THE SMILEY TRANNYS" crowd goes wild, baseline drops, you get the picture.
(13-06-2017, 06:22 PM)Dum-Dum Wrote: It should be a motto for everyone!
brings so many odd images to mind (Ru Paul anyone?) ninja
Hate Housework!
  Danny's MK5 Transit camper. With added 508d content. Transit for sale. £1500. Danny Wideboy 60 44,064 06-01-2019, 02:16 PM
Last Post: Niall
  Transit pug306driver 2 4,129 18-06-2018, 12:35 PM
Last Post: pug306driver
  Danny's rusty transit. Danny Wideboy 18 12,119 01-03-2016, 08:20 PM
Last Post: Danny Wideboy
