What pressure does the LP pump run at
So does anyone know this? Or anyone know when the ecu will cut in limp mode. Trying to work a few things out and cant find any data on it
the low fuel pressure is triggerd by the hp pump but the lift pump runs at 37psi i think
The lift pump is regulated to 1.25bar within the fuel filter housing.
The ECU has no clue over the low pressure circuit, however if the low pressure circuit starts starving/dropping pressure, the HP pump will be starved also, which means it'll fail to make pressure. As stock there is a maximum ±250bar deviation allowed before a fault code is set.
Well ill have to see what pumps i can find that will make my life easier. Thanks for the info guys
what do you need to do? higher pressure lift? more flow? might be able to point you in a direction mate.
/Toseland
Just need to know what the standard ine runs ao i can measure it against another one i have
Iirc the pump itself runs at 3 bar, if you're testing it seperate from the fuel system. Otherwise as Ru says.
the pump will typically run at whatever pressure the regulator is set at, so if you need more pressure then change the regulator.
Thanks for all the info guys. Ill test what i have and go from there
(20-03-2017, 05:01 PM)welshpug Wrote: the pump will typically run at whatever pressure the regulator is set at, so if you need more pressure then change the regulator.
This is a very valid point.  lol
I dont require more pressure. I just neesed to know stats for testing purposes. As usual the forum has deliverd some stuff for me to look into
  Cleaning low pressure pump pick up? JTaylor2005 7 4,196 08-11-2016, 01:42 PM
Last Post: Piggy
  306 hdi high pressure pump Dougieboy1 18 9,215 08-02-2015, 02:49 PM
  Upgraded fuel pump and pressure sensor JTaylor2005 18 10,924 04-12-2014, 09:15 PM
