Xud ph1 bianca
Ph1 bianca project started out as a base model straght d so far has had xud built for it whit 16v hdi rods new big end and crank bearings new set of piston rings.5 notch mls headgasket.arp head studs. Gt2052 whit 10mll and all new seals.
Shell is getting a good bit off welding done and a good tidy up and respray.
Plans are to mtdi a dw10 for it at some stage and put the xud into the 405
Attached Files Thumbnail(s)
