change radiator to none hdi radiator
i want to remove the hdi radiator and replace with a different 306 radiator that has the built on expansion tank on the side. in the process of tiding up the bay and would rather a one piece unit than the expansion tank ontop looking a bit naff. Does anyone know if its a straight forward swap or will i need alot of piping aswell?
Remember doing this when i phase 1 converted my old hatch but caused no end of heating problems. Seen a few people using ali 180sx rads but this is somthing id like to look into aswell.
Have been wondering if its poss to swap it for a 3" core honda rad as there smaller but volume will be similar
[Image: 8cc9969ad98344729678bf661ddafc6a.jpg]
Pictures useless but had done it
Really easy to do. No worse than a rad change. You can do most of it with no issues just need some extra pipe and some joiners. Lower rad pipe as well
  Aircon radiator 306 hdi mattbarker32 7 1,420 31-08-2016, 11:45 AM
Last Post: mattbarker32
Rainbow Coolant radiator refilling procedure Welshy_Pete 7 1,021 20-03-2016, 11:52 PM
Last Post: Welshy_Pete
  306 radiator same as 307 radiator? 306rhys 7 1,113 06-10-2015, 05:54 PM
Last Post: Poodle
