Threads: 476
81
Car Model/Spec: 306 Rallye
I was looking at this the other day. I presume you've got a battery charger... So all you need now is like the quids worth of soda some water and some metal bars.
Threads: 67
1
Car Model/Spec: 1.9 Xud
Given 0 thank(s) in 0 post(s)
As above, that's all I use .
Soda crystals from tesco are a £1 for 1 KG last time I checked
Threads: 476
81
i guess so. I think it would just go slower but if youre leaving stuff overnight not sure it matters too much.
Threads: 48
4
11-02-2017, 10:44 PM
(This post was last modified: 11-02-2017, 10:45 PM by Ben_w.)
Let me know how you get on.
Welcome to lob them my way if you struggle. Won't take 5 mins to fire up my set up again. Only payment terms are Henry Weston's Vintage
Threads: 476
81
oh wow thats super impressive? what did you use as the electrode in the bottom of the pot?
Threads: 48
4
Any decent sized bit of scrap steel will do.
I use an old brake disc
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
I used some steel bar from b&q. Cut in half and bent over edge of the tub and then connected using some copper wire. Not much surface area though so will try and get an old brake disc like ben
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 32 thank(s) in 32 post(s)
wow, im so gonna give this ago
results are just too good
Threads: 162
21
Car Model/Spec: 306 HDI Dturbo, Estate & GTI6
Given 23 thank(s) in 23 post(s)
How much soda to how much water did you use?
Threads: 186
38
Varies, think 1st time was 20l to 0.4kg. I tried stronger mix but charger got hot and cut out so back to weak
