Threads: 117
119
I would say that's an issue with your ignition switch.
Threads: 1
0
Car Model/Spec: 306 HDi
Given 0 thank(s) in 0 post(s)
Country:
ignition switch i dismantled the problem persists
When disconnect the fuel pump double-relay clicking of the mute but begin to click ABS cube When you disconnect the ABS cube chattering stops, dashboard still lights
sorry for my englisch i used google translate
Threads: 117
119
Well that's a strange one, i'm not sure what else to suggest beyond looking for damaged wire sheathing on the ignition loom. Without that switch being turned on there simply shouldn't be any power going to most of those components, therefore it's got to be a problem on that circuit in my mind. Probably something i've missed, i'm not much of an electrician.
Threads: 117
119
05-02-2017, 03:52 PM
(This post was last modified: 05-02-2017, 03:52 PM by Poodle.)
I would hazard a guess thats your ignition fuse, i bet you won't get anything when you turn the key now.
This is one for Cully really.
Threads: 1
0
Country:
Lihgts, blinkers etc. everything work. Car doesnt start also without fuse......
Im back where i was. The fuse almost doesnt solve anything. By the scheme it should connect fuse's cabinet in the car but it works also without fuse except central lock.
Just all of the relays stop to snap and dashboard turns off but the dashboard sometimes turns on when there is no fuse. And sometimes the ABS cube starts to snap.
Motor cant turn off even when the key is out and when i disconnect baterry plus pole then it stops after minute.
But it was it wasnt happen that the car was doing normal that the controls turn off and stop snapping.
I opened the fuse's cabinet small and big, if they are not oxidised
We disconnected alternator, drv valve, all fuses and relays, airbag, Incandescent, switches, dashboard, ignition......
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
This seems like a really stupid thing but have you tried to reset that emergency switch by the ecu
/Toseland
Threads: 117
119
That's a fuel- cut switch, wouldn't affect the ignition.
Threads: 1
0
Car Model/Spec: Peugeot 306 HDi
Country:
I have problem with starting too... I was changing all filters and oil... Today i wanted to start the car,it started,bud after 5-10 seconds it turns off the engine... Looks like problem with fuel,but i have checked everything i could.
Threads: 117
119
Try bleeding the fuel system through. It's self-bleeding so just turn the ignition on 3 or 4 times for five seconds at a time.
