Rpm sensor xud11
Rpm sensor xud11
Okie dokie so sinse I've done a but of hunting in the bath earlier and came up short I need to know I remember reading a thread about dropping the in a 306 in standard form...and it said about drilling the block for the RPM sensor? Any comments welcome but if anyone could shed some light on the whole situation that would he much obliged I probably looked in the wrong places as I'm new to the forum but any info would be muchly appreciated
Sambo
 LET THE BODGING COMMENCE
 BUILT IN A BARN IN SOMERSET
As I said when I messaged you... Its in the racetractor thread early on and there is a guide to fitting the xud11 in the guides section, also in there ThumbsUp
(18-01-2017, 07:21 AM)Piggy Wrote: As I said when I messaged you... Its in the racetractor thread early on and there is a guide to fitting the xud11 in the guides section, also in there ThumbsUp
Yeaa piggyy can't find that forum.
Well you are already on the forum...
Admittedly admin need to add the xud11 guide in the guides section...but it is marked as a top thread right at the top of the xud section!
And my Racetractor thread is under my threads!
C'mon Sambo!!
  lower height pistons xud11 of 1 mm niciou 3 5,173 01-03-2018, 07:44 PM
Last Post: niciou
  How To - 2.1TD Swap / XUD11 Fitting Dum-Dum 101 93,295 28-07-2017, 12:18 PM
Last Post: rachaeljf
Wink The judge and its xud11 Sambo the bodger 37 14,183 24-06-2017, 06:04 AM
Last Post: bashbarnard
