Megane mk3 headlight adjustment
Looking for how to adjust the headlights the other day, I found the adjustment for up and down its located on top with a allen key/phillips screw driver bit to adjust....
I also found on the back of the head light, a white plastic male bit of an allen key (8mm socket fits on to it), I moved it around a little and I couldn't see it doing anything.
Does anyone know what this is for?
It will likely move it side to side
I thought that may be the case, but when i moved it nothing seemed to happen, perhaps it wasn't enough I shall try it later thanks piggy Smile
As you said piggy it was left to right, wound it in a shit ton an the right side was point to the left kerb Smile
ThumbsUp Smile
  Megane clutch bleeding rocker8742 13 6,665 06-01-2017, 09:38 PM
Last Post: rocker8742
