1.8 16v ecu, ignition barrel and front door locks
Tongue
as above please, need the ecu to be soft unlocked (unplugged while running) so i can remove the immobiliser pins
posted to birmingham, thanks in advance
Current cars
Subaru Impreza 2.0d - Daily
Bump
Sent from my SM-A300FU using Tapatalk
Current cars
I've got all that here but can't start the car anymore as the ignition barrel has been removed, guess that's no good to you?
Have you still got the ignition barrel? If youve got the ecu, bsi, barrel, door lock and key then ill just fit everything
Current cars
you dont need the barrel, all you need is the fob alarm ecu and engine ecu
Ignition barrel is gone I'm afraid, got a key left though.
I know but the barrel is also missing from the car hence i want a barrel to
Current cars
No worries lads scrappies actually had 1
Current cars
Rainbow Wanted: Door handle front diablo red Welshy_Pete 2 3,230 05-07-2017, 05:46 PM
Last Post: Dangti6
Rainbow Wanted: ignition key barrel + door locks + keys Welshy_Pete 8 9,457 18-06-2017, 07:57 AM
Last Post: Welshy_Pete
  Wanted: 206 ph1 ignition barrel/key Piggy 0 1,966 26-06-2016, 04:43 PM
Last Post: Piggy
