Front fog light bulbs blowing
As title really.  Fitted new bulbs just over a week ago only had to put the lights on twice and the drivers bulb has blown
Could it just be a bad bulb or something more?
I'm pretty good with a multimeter and such just want someone to point me in the right direction so I'm not spending hours trying to find a fault
did you touch the glass with your fingers? is the seal leaking?
is it actually foggy and visibility under 100 feet?
Are you sure it's the bulb blow and not the connection where it plugs into?, I had a problem where at times it used to come on but then later go back off I thought it was blow until I unplugged it and plug it back in and it used to turn on that's how I figured out the fault hope this helps
[Image: jhhjjhjhjh.jpg]
  Battery warning light/fuse keeps blowing.HELP Clump1298 8 7,038 03-09-2020, 08:21 AM
Last Post: ekjdm14
  Rear wiper blowing fuse 28 MattDanPug 5 5,562 22-09-2017, 04:08 PM
Last Post: Mighty306
  Blower fuse keeps blowing Teddy 16 9,573 03-11-2015, 08:22 PM
Last Post: Teddy
