Anyone got DW8 engine manual?
Need the specs for a DW8 engine - can find some of them online but haven't got the whole lot... I need;
Cam bearing journal diameter + tolerance
Valve Clearences
Valve stem diameter + tolerance
Head flatness + tolerance
Deck flatness + tolerance
Bore diameter + tolerance
Piston ring gap
Big end bearing diameter + tolerance.
Cheers,
Laurence
will be the same as the xud most likely.
haynes manual probably has it.
(07-12-2016, 11:47 AM)welshpug Wrote: will be the same as the xud most likely.
Xud has a different head I believe? May be wrong...
