how to clean bare engine block
any suggestions. as cheap as possible just got to clean it for paint this weekend. its completely bare, need to able to do at home with minimal tools and expense as its the boring part i don't like spending money on the boring bits
Isn't MR Muscle/oven cleaner meant to work well?
(11-11-2016, 10:08 PM)1616six Wrote: Isn't MR Muscle/oven cleaner meant to work well?
fair enough i use it all the time on turbos lol never really thought about it on a block to be fair.
Sounds really f*cking nasty but stick it in the dish washer if you have one.. it WILL Bring it up lovely and is reasonably easy on the engine's more sensitive parts..
Mrs BAsh might not be so easy on your sensitive parts if she finds out mind
/Toseland
Oven cleaner and degreaser from local car parts (or work stores!) works a treat with some pressure action too!
Team Cyril
If there is an engine machinist nearby they will probably dip it in their tank for a couple of quid, that will do the best job.
They might charge as little as a couple of cans of Mr Muscle?
grinder with a wire wheel, brake cleaner then paint
GTI6 Info
Gunk does a decent job of some stuff.
  bare jokes fam impotentials 52 23,449 21-09-2014, 08:40 AM
Last Post: toseland
  Using ATF to clean engine? lolsteve 13 6,748 11-08-2014, 10:06 AM
Last Post: r3k1355
