Wanted - Phase 1 1995 Dashboard Loom
Hi,
I'm after the loom that goes behind the dashboard ideally from a 1995 306. Mine has had a few bodges carried out by a previous owner and is causing me a nightmare with electrical gremlins. Ideally would like to have the dimmer switch option for the dash lights too. I'm guessing it would be ok to use the loom from either a diesel or petrol 306 but it must be in working order. Let me know if you've got one and what you're after for it.
Thanks.
PH1 FTMFW!
I have an unmolested loom from a 1996 phase 1 gti6 with dash dimmer plug on it, would need to remove it at the weekend though.
Sensible offer and it's yours Smile
Also have dash loom mate if you need it Smile
Still after this if anyone's got one? The gti6 didn't have the same connectors for my air bag and pre tensioners Sad ideally after a complete dashboard with loom
PH1 FTMFW!
Still after this, ideally from a d turbo as mine is a mess behind the dash. Got the money waiting. Prepared to travel and take the dash out if needs be Confused
PH1 FTMFW!
If I knew how to remove mine would sort it
Have a look at the guide about changing the heater matrix that tells you how to get dash out. Cool
PH1 FTMFW!
(01-01-2013, 09:29 AM)SKoob Wrote: Have a look at the guide about changing the heater matrix that tells you how to get dash out. Cool
Will look for it
i will have one soon from a N reg dturbo
How much for it delivered mate?
PH1 FTMFW!
Spike, you don't have a full loom anymore - I chopped some plugs lol :O
  Wanted: Phase one D-Turbo loggie 2 3,556 23-01-2021, 08:56 AM
Last Post: loggie
  Wanted phase 1 306 rear n/s arch liner Karlos89 1 2,713 05-01-2019, 10:19 PM
Last Post: doogle-d turbo
  Fog light glass lense phase 3 wanted Teeharv 1 2,465 27-06-2018, 11:37 AM
