12-10-2016, 08:01 PM
If your not into roadkill but like Cummins or vice versa I suggest you watch this
Roadkill ep55 - Cummins Swap
12-10-2016, 08:02 PM
Edit:
If you are a man. You will like this. If you are a woman, you should like this. Wishes for more power...
12-10-2016, 08:05 PM
Also worth pointing out here, this is a true sign to the shear size of these US spec barges, that cummins literally dropped into that Caddy...like stock..if you have SEEN the size of a 12v cummins, you will understand my point here! We had to shoehorn it into a landrover! Nevermind a car!
That said, the MX5 with a cummins is a fair achievement , that said bonnet didnt get away quite so lightly in that build! | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
12-10-2016, 08:11 PM
(12-10-2016, 08:05 PM)darrenjlobb Wrote: Also worth pointing out here, this is a true sign to the shear size of these US spec barges, that cummins literally dropped into that Caddy...like stock..if you have SEEN the size of a 12v cummins, you will understand my point here! We had to shoehorn it into a landrover! Nevermind a car! Wasn't it only a 4bt in the MX5. But yeah Cummins engine alone (before adding that big ZF box) is over a meter long, over a meter high and for scale that is a fair size Holset turbo hanging off the size as standard, like I don't think a DTurbo could even spool that unaided. So excited to get mine.
12-10-2016, 09:43 PM
seen it already and it was epic!
spotted the lda pin mod going on as well!
13-10-2016, 08:55 AM
13-10-2016, 09:11 AM
Never heard of Roadkill before, and it's now my favourite thing on in internet.
13-10-2016, 05:10 PM
14-10-2016, 03:57 PM
I've got motor trend on demand so get it all much earlier than YouTube. Also check out hotrod garage, engine masters and roadkill garage.
| Cummins 6BT in an RX8 | Dum-Dum | 15 | 8,932 |
05-12-2016, 10:49 AM Last Post: darrenjlobb |
| Newest Roadkill - Stubby Bob is Back | bigcheez2k3 | 7 | 4,952 |
17-07-2016, 08:41 PM Last Post: Ben_w |
| Roadkill | bashbarnard | 16 | 8,859 |
16-05-2014, 07:35 PM Last Post: Curt |
