Threads: 15
0
had a good search and cant find anything about this but i have no reverse light, the reverse light switch on the gearbox works as i tested it with multimeter but its not getting any power to the terminals at the back of the car. anyone got any ideas what/where the problem might be, thanks. and just to add.... all the fuses are fine
Threads: 124
26
Car Model/Spec: Megane DCiR
hows the condition of the rear board where the bulbs plug into mine was rusted in and hence y wouldnt work. you dont need one for legality but helps stop people driving into you when reversing
Threads: 15
0
i checked with the multimeter ant its not getting any power to the rear of the car at all not even at the plug
Threads: 124
26
:S not too sure i know mine had a dull side which was due to a bad earth i wonder if this could be why your not getting anypower at all, im not a genius with electrics im sure you will get the reply you want in no time on here though sorry couldnt help anymore
Threads: 15
0
thanks for your help, if anyone knows where the relevant earth is, to check, that would be great.
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Brakelights ok? Mine keeps popping fuse 5 which is for reverse lights and brake light switch. Its a 25a fuse 5 from the left on the bottom row under the dash
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 15
0
yeah all fuses are fine I've checked and double checked. brake lights work, becoming a bit of a mystery!
