Bosch Cold Idle spring Wanted! £10!
As above after the hot/cold idle spring i will pay £10 for it as i need one!
www.prestige-auto-care.co.uk
Jenkosowls Wrote:As above after the hot/cold idle spring i will pay £10 for it as i need one!
ill be taking it apart tonight. so you can have the one i have. td_dan wants the pulley and key.
lol ben can make his money back in no time
ginge191 Wrote:lol ben can make his money back in no time
i wish...any one want any other bits from it?!
Is this the bit you wanted?
[Image: IMG_0581.jpg]
[Image: IMG_0582.jpg]
also do you want the arm as well?
Doubt it Ben.
It's probably the smaller spring inside the pump which attaches to the governor cradle assembly.
Captain Standard
It's internally Ben it's a spring with two loops on the end and attaches to the other lever on the opposite side you'll notice it when you split the pump. Have a look in the gov mod guide its in that
ah right. ill have a play tomorrow then!
  Wanted: Wanted - Bosch setup Dazecoop 1 1,897 06-04-2016, 01:32 PM
Last Post: silverzx
Exclamation Wanted: Bosch ve idle spring needed asap / worcs area zx_volcane 6 3,093 21-10-2015, 10:41 AM
Last Post: zx_volcane
  bosch ve advance piston and idle spring rryan 6 3,160 13-06-2015, 09:34 PM
Last Post: rryan
