4.9 cwp for 5speed be3 gearbox
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
After a 4.9 cwp for a 5 speed be3 gearbox  , apparently fitted to early pre 2001 Citroen Berlingo / Peugeot expert 1.8 non turbo diesels , ew10 308 have 5.06 , ratio on final drive is 15 x 74 = 4.9 or 15 x 76 = 5.1 , anyone got one or anything close ,
Bump , still after if anyone has one
INbox me details on exactly what car to find the correct CWP on and im sure i can sort you something Smile
Team Cyril
Is this to lengthen the final drive for economy gearing?
Isn't there a box from a 206 eco model that does similar?
I should have done this mod previously, doing 2k a month currently...
(26-09-2016, 01:43 PM)Matt-Rallye Wrote: INbox me details on exactly what car to find the correct CWP on and im sure i can sort you something Smile
Pm sent matt
Need to watch out here as some use a diff dia shaft, no issues thou as the 206 Gears fit
(27-09-2016, 09:00 PM)miles Wrote: Need to watch out here as some use a diff dia shaft, no issues thou as the 206 Gears fit
Miles am on close ratio be3 gear set , so don't really want to go changing to 206 gears , thanks wayne
307 will have a be4 like the 206.
(27-09-2016, 09:07 PM)welshpug Wrote: 307 will have a be4 like the 206.
Cheers welshpug , that can be crossed of the list then
Still after a 4.9 cwp for a 5 speed be3 box
bump , still looking for cwp
