XUD BITS
Wanted: XUD BITS
t2 turbo with oil line
in tank pick up
possibly xud harness
absolutly cheap as pos please. may not even need them but im putting out feelers now
bump anyone
think i do have the turbo, will check
(20-08-2016, 06:21 PM)welshpug Wrote: think i do have the turbo, will check
thanks man
found it, its complete, feed and drain are there too.
(21-08-2016, 03:12 PM)welshpug Wrote: found it, its complete, feed and drain are there too.
Pmd
Also need a phase 1 front bumper gti/xsi/dturbo
set of phase one green dturbo s seats
Also xud air con setup, bracket tensioners alternator pas pump etc
I've got the bracket mate?
Holds PAS, aircon and alternator.
Can get a photo for you. Came off the 406 engine, think it's the same
Edit: I've got the PAS, air con and alternator if you need
Can you get me pics man please. Going to keep the aircon on the xud conversion if at all possible
(24-08-2016, 07:36 PM)bashbarnard Wrote: Can you get me pics man please. Going to keep the aircon on the xud conversion if at all possible
Sent from my iPhone using
Sure thing; should be back up the yard tomorrow.
