Best wish bones to buy
Hi all :Smile
            I need to replace both my wishbones on my 306 hdi 1999,
Where is the best place to get them from,
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
TRW from Misterauto, around £35 each /Thread
^^^That tbh. Don't be tempted by the cheap crap on ebay, quality is awful and they've been known to snap more than once!
meyle HD ones are good and come with pbushes and ball joints. about £90 the pair i think.
i never buy wishbones, just replace the bushes.
(22-07-2016, 10:50 AM)welshpug Wrote: i never buy wishbones, just replace the bushes.
this if you've got genuine pug wishbones
or if you don't have a press ..etc then can recommend Meyle HD, even though I've had P-Bushes go on the pair I've had they did come through with a guarantee in the end I was refunded.
dont need a press, some threaded bar washers and sockets will do it.
(22-07-2016, 11:10 AM)welshpug Wrote: dont need a press, some threaded bar washers and sockets will do it.
to get the old ones out?
had a mare with the last set i did, resorted to fire and swearing in the end
(22-07-2016, 10:24 AM)Eeyore Wrote: meyle HD ones are good and come with pbushes and ball joints. about £90 the pair i think.
meyle HD sounds good to me :Smile  do you have a link please
306 HDI
stage 1+ remap
hole cutter grinder and chisel to remove old bushes.
Grinder to slice through p bush...then smack it.
Front bush, take blade off hacksaw, run through then reattached and cut through...then smack ouf
If you are taking it to a garage, then going the replacement bush route will cost a bit less in parts and a bit more in labour.
If you're going for replacement arms, then parts will be more and labour will be less.
You've got a stage 1 remap + some other performance parts, so while you are here, grab some powerflex polybushes and for the P bush I hear Citroen Berlingo P Bushes are an upgrade, slightly stiffer bushes will get you handling that bit better.
Same as what so other the others have said, i would rather stick to original arms and just replace the bushes after seeing some of the aftermarket arms snap bushes off from the poor build quality.
That said if you are going go for arms it's better to go for decent brands like TRW or meyle HD ones. It does save the bit of hassle fitting the bushes.
febi if you can find them
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
  wish bones Carlos vinyls 2 2,353 26-02-2013, 06:50 PM
Last Post: puglove
