22-06-2016, 02:21 PM
Hi all as above I'm having problems with my 11mm pump I've done the conversion following the guide on here and it all works fine the car runs well and idles well
In doin this tho I'm really not impressed with it I was expecting a massive difference but it hasn't really done anything I've gained higher revs threw the gov mod and about 2 psi more boost apart from that nothing else really made a difference. But if I turn the max fuel screw any more the engine won't die bck down to tick over when Rev it up. I have hardly any black smoke on boost unlike the old pump yet keeping the power of the old pump.
The lda has been done the gov mod been done and all the head apart from the delivery valves has been changed also the fuel line has been upgraded from the tank to 12mm so supply isn't an issue its a really brain teaser and what ever I do makes it worse really can't get it any better so any info or ideas be great thanks
Also the waste gate on turbo is as short as I can get it and only just pushes 22psi but the turbo will be changed soon the turbo on at the minute is a td04 but being changed when flanges are made up to a gt2052vnt running a boost can many thanks in advance
