Throttle Position?
Throttle Position?
Hi guys,
I have the torque app on my phone and it has a throttle position % read out on it. Mine only goes up to 99.2% which I know isn't all that bad but I'm just wondering what it could be that is causing that? Am I right in thinking that it doesn't go through a variable resistor? Its a pulse setup?
I have tried just turning the throttle under the bonnet to full open and that hasn't taken it up to the full 100%. Could this be hints that the TPS isn't in great condition.
Im pretty sure when I put the torque app on originally it would reach 100%.
Do you reckon it would be worth stripping it down and cleaning it all out and re-greasing? There is a guide on here someone I will find and get it done this weekend along with my service.
Thanks Smile
Guide looks easy enough Smile
http://306oc.co.uk/forum/showthread.php?tid=9969
Get it on PP2k and see what that says.
If your ELM light isn't on then the TPS will be fine.
Jack just likes finding problems tbh... Tongue
Its fine, that 0.8% doesn't matter... lol
I do I like to mess. I might just do that guide anyway Tongue I just noticed it weren't there last time I used the app Wink
push the pedal harder Tongue
Haha I tried that Tongue It didnt work Sad
It's fine, if you look at calculated engine loads, you'll see the engine runs at 100% over ~95% throttle anyway. It's probably a safety feature anyway, I'm willing to bet all HDi's do not go to 100% as that would indicated a fault. iirc mine also goes to 99.2%
100% - short circuit?
Hate Housework!
(22-06-2016, 06:06 AM)Magenta Sunset Wrote: 100% - short circuit?
100% = 88miles an hour and we know where that leads!
/Toseland
6th gear...
yeah! getting hit on by your mum! Blush
Hate Housework!
Probably rounding error in the OBD protocol.
If you really must know, get yourself an ELM327 adapter and poll the ECU for the TPS PID and get the raw data back and do the conversion that is specified in the PID. I bet you it'll come back at around that value.
  Throttle position sensor 2 error code ?po221? nollafnhoj 12 7,889 15-01-2014, 10:57 PM
Last Post: Poodle
  Turbo position repeat valve Daniel306 7 2,224 15-11-2013, 06:50 PM
Last Post: Daniel306
  boost control hold position 306 ANTB1986 16 4,789 18-06-2012, 09:14 AM
Last Post: Poodle
