Spark plug cover
How do you guys remove the T30 bolt under the master cylinder on the spark plug cover?
Short draper bit and a 10mm rachet spanner
P1 XSi track car
2.4 LWB T4
I thought they were hex not torx?
I use an allen key there i'm sure, regardless.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Yeah I use an Allen key as well, pretty sure they're Allen unless yours have been changed.
they varied, also some of the cable guides underneath use torx.
Bought a little bit ratchet and cut down a t30 bit 5mm each side.
[Image: IMG_20160610_210135_zpsiciyon7m.jpg]
[Image: IMG_20160610_202711_zpsdwmcqy7j.jpg]
Sent from my Nexus 4 using Tapatalk
yep ive had both. swapped the torx ones out for the hex ones.
  Spark plug colour gti6man 7 5,016 26-08-2017, 10:42 AM
Last Post: bashbarnard
  spark plugs MrMarlboro 3 2,802 16-05-2015, 03:01 PM
Last Post: PocketFighter
  spark plugs ripp444 2 2,474 17-03-2014, 05:51 PM
Last Post: ripp444
