Slimline Fan Wiring
Hi Guys,
Being a little lazy here but after opinions and advice. Previously I had a fuse, single relay and one medium size slim line fan. This was all good and worked well. Now on the rallye I have 1 fuse, 1 relay and two medium fans. Should I have two relays or not? I guess i need to check the rating of the relays?
Sam
answered your own question
or run a separate fused supply and relay for each fan
GTI6 Info
Tbh, it would be much better to run them independently. that way if a fuse pops, or relay burns out you still have 1 fan.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
You can run two fans independently on the Omex so you could have one for low temp and the other kick in as well at high temp. This would require 2 relays.
I always ran mine together on one and never had issues.
  how have people installed and wired their slimline fans? MY95 22 13,050 25-06-2016, 06:46 PM
Last Post: Sambarker
  Fans...HDi fans... HDi slimline fans... wiring.. toseland 3 3,740 07-09-2015, 09:52 AM
Last Post: cully
  Hdi slimline fan wiring Jtrigga 5 4,070 28-08-2014, 05:58 AM
Last Post: bashbarnard
