Threads: 136
11
24-05-2016, 07:23 AM
(This post was last modified: 24-05-2016, 07:27 AM by Paul_13.)
Going to be changing the head gasket and the turbo at the weekend on the hdi
Just need a bit of advice from some one who's done this before .
I know the head bolt torque settings in Haynes is wrong
Is it turbo/exhaust off first and then carry on with the HG or can you undo all the head bolts and lift the head/turbo/inlet as one?
Obviously if taking the turbo off, subframe off
Done plenty of he's before, just would appreciate what order things need to be done in to save some time
You'll find if you're doing the turbo its easier to lift the lot...its just ruddy heavy
Given 117 thank(s) in 116 post(s)
Is there space to lift the head off with the turbo attatched?
Given 105 thank(s) in 105 post(s)
Pretty sure i've pulled a head off with the manis and turbo still attached before, think i had to drop it off the top mount, i'd get a mate to help you lift it though.
Threads: 136
11
You don't know me well enough lol won't need any help
Thanks for the tips should speed things up, hopefully be able to do the same with the gt2052s
Threads: 50
Car Model/Spec: 306 HDI Dturbo
Can't offer any advise sorry but I'd be interested to hear if it's do-able. Good luck!
