High pressure diesel pump
My 306 has given up the go and I believe I require a HP PUMP as in tank pump still works car turns over just has no final oomph to start please help me
Get it on diagnostics... Could be a number of things... Often found the HP pumps to get worn...but actually rare to completely fail
There's no management light on would it still come up with a fault on diagnostics?
It should do, yes. Unless it's an ecu problem, in which case it will not work properly.
  Wanted: 306 HDi PAS high pressure pipe Poodle 0 1,374 30-11-2015, 03:08 PM
  Wanted: 205 diesel 106 or spaxo diesel poss a metro diesel ash23 2 2,550 17-12-2013, 02:11 PM
Last Post: ash23
  T25 high pressure oil line Teddy 2 2,047 26-11-2013, 02:06 PM
Last Post: Teddy
