Bosch pump with gov mod
Hello,
My bosch pump has strung a leak on the throttle shaft I'm pretty sure, not got the time to repair a pump need a bolt off and on job
Anyone got a pump with gov mod done to it, need just the pump no lines or injectors
Thanks
It's a small job changing the throttle shaft seal, way smaller than changing the pump... Smile
Can be done in situ in case you were wondering.
  Wanted: XUD Bosch Fuel Pump xstian 0 2,683 02-06-2020, 08:08 AM
Last Post: xstian
  Wanted: Bosch pump nominous 0 2,087 17-01-2018, 12:19 PM
Last Post: nominous
  Wanted: Modified bosch pump Chris_90 2 2,825 27-02-2017, 08:24 AM
Last Post: Chris_90
