Headlights
Headlights
This might seem a bit silly but how do u get the level adjusters out and put the phase 2 adjusters in
Thanks
twist, and then pull. they've got a couple of lugs, turn it about 90* irrc, then ull to get the ball joint to pop out.
to get it back in, you'll have to take off the bulb access panel then hold the reflector while you push the adjuster on. feels like you might break it, but you wont. it'll pop in before it breaks
