GTI6 beam fitted, front end now has more roll
#61
Yes was fully refurbished, bought it off a guy on the GTI forum, was fitted to car and was far too low, then the ride height was changed and set to standard the proper way, although now sits a bit higher on the left (although was done to 330mm apparently), will have another check on flat ground, but sure its a bit out. Is a GTI beam with solid mounts, hence much stiffer at rear than front of the car at the moment.
When it was raised back up to standard height, was it done with a dummy shock? If not, it's quite easy to get it slightly out side to side if doing it by eye or using a tape measure.
It's been a while since I've done a 306 beam, but 330mm sounds about right for standard height with 20mm torsion bars (which is what a GTi-6 beam has)
Wasn't done with dummy shock, just a tape measure, so guess there was probably a bit of error there, really unsure on what to do about stiffer front end now, don't want to have any more understeer from fitting the GTI ARB but don't really want to go any lower, hmmm.
from memory the DTurbo HDI has the same springs as a rallye.
330 is what I set all the standard 20mm bar beams for a 306 to.
That's interesting welshpug, I used to have a rallye, and it definitely sat lower, will dig out the photo now.
bet it was on 50's :p
did the hdi also have its ac removed?
Rallye was on 50s on the front and 55 on the back in that photo when I got it lol HDI was on 50s all round.
HDI didn't have AC removed then, has now though, why do you ask? Smile
ah, 55's on the back as well as 50's on the front will bring the nose down even further!
50 profiles? Putting the right size on would give you a bit more clearance for a start lol.
Yeah always ran 50s Tom, never driven a 306 on 55s aha lol
Lol, 55s make a huge difference, more comfortable, fill out the arches better, raise the nose end a bit etc... Smile
Just a shame they cost so much more!
That's the issue Tom, plus they don't do Michelin PS3s in 55s either :/
Other brands are available though... lol
That said I would like to try PS3s tbf.
Yeah PS3's are just quite something! so what about mk1 xsara vts 1.8 struts/springs, should be stiffer and a similar height to 306 HDI due to similar engine weights?
Are there any VTS 1.8s? Pretty sure VTS was only the 2.0, essentially equivalent to GTi6.
The 1.8 is a fair bit lighter than the HDi though tbh, but I guess they may've done a sports one with uprated suspension, not sure.
The MK1 VTS had the 1.8 112 Tom Smile
So just wondering if the suspension on that will be stiffer, similar ride height and better (as it is a VTS model, and has better steering rack/axle already)
Crikey, that must've been disappointing for anyone buying one. lol
It's probably got the same springs as a 306 1.8 XS in that case, they sit about the same as the DTurbo HDi and GTi6 but have the lightest engine.
I don't know if the shocks will be any shorter though, as they are on the 2.0 VTS.
not in the UK, all 2.0 iron block
Here you go Tom Smile http://www.carfolio.com/specifications/m...?car=86779
  Gti6/VTS Front Shocks/Springs MY95 14 3,011 05-10-2016, 08:23 AM
Last Post: Toms306
  GTI6 rear beam and front legs Frankwood 1 909 10-05-2016, 08:09 PM
Last Post: Mattcheese31
  GTi6. beam bearings and stub axle measurements Ben_w 14 3,034 01-06-2015, 05:22 PM
Last Post: Ben_w
