heater box conversion
there are two listed under my chassis on service box
post edited. i have both boxs how hard is it to put the valeo one in my ac model one
AC and non AC.
Already told you that Tongue
Lol, as above, Valeo for non-ac, Behr for AC.
but both are listed under my chassis number!
Servicebox isn't failsafe. This is one area where it really is that simple, not like trying to identify ball joints lol.
(18-04-2016, 07:46 PM)Toms306 Wrote: Servicebox isn't failsafe.  This is one area where it really is that simple, not like trying to identify ball joints lol.
i just went outside and pulled down the cover under the glove box. behr
changed first poist
You'd need to pull the whole dash out to change the box where you can get away just pulling it forward a bit for the matrix, and change the heater dials and possibly loom on the box. Its a lot of hassle for no real gain that I can see?
(18-04-2016, 08:50 PM)Toms306 Wrote: You'd need to pull the whole dash out to change the box where you can get away just pulling it forward a bit for the matrix, and change the heater dials and possibly loom on the box. Its a lot of hassle for no real gain that I can see?
I have a valeo box in with a free heyer matrix that was only done just before i got it
Ah ok, makes sense. It would be more effort, but cheaper if you don't have to buy another matrix.
you need to cut the hole in the scuttle panel, use the non ac control panel, non ac heater control wiring.
remove ac pipes and block hole in bulkhead.
i think all that work is worth far more than the difference between ac and non ac matrixes.
Yeah I've already told bash all that welshy
Hmm we will have to see. Id rather not cause myself extra work atm but im running short of funds untill payday. Ive got a few jobs on this week though that should help out. Ill see if the motorfactors can send up both valeo and behr so i can compare and see if the valeo one will fit as its £30 cheaper
no it wont fit.
many have tried lol
Just get the right one. It's painful enough as it is
