Peugeot 206 Heater blowing cold
Hi guys,
I appreciate this is the 306 forum, but I know you lot are supper knowledgeable when it comes to pugs so I'm hoping you can help. I've got a 1.4 petrol 206 and the heating blows cold. I've looked on other forums and I have checked the thermostat, water pump, heater matrix and everything is fine. There are no blockages or cold spots on the rad or pipes etc. Everything is flowing nicely and the car doesn't over heat or anything like that. Hot water is going into the matrix and flowing out the other side so the water system is fine. I'm a bit stumped as to what it can be. The fan blows on all settings as it should it's just the air comes out cold no matter what! Any ideas? Thanks
Might be better off trying the interior section, sounds like you've got an issue with the hot/cold air flap thingummies.
