Engine warning light
Well it finally happened - after 7 1/2 years the engine warning light has finally come on and stayed on.
The car is driving normally, fuel consumption is the usual and oil/water levels are good.
I did notice a couple of weeks ago that the engine idle is staying a bit high, but only when the ambient temp gets to about 10c.
Stop at a junction and it idles at about 1200, before slowly dropping to around 1000.
Other than that, everything is normal.
What are the most likely causes for an engine warning light considering the above info?
Thanks.
Jay
2002 1.8 16v petrol Meridian estate 79k miles
at a guess, most likely the throttle sensor.
Hate Housework!
Sounds like the ICV causing the idle issue. They don't usually bring on the engine light though.
icv? whats that?
Idle control valve.
ah, just spotted, ita a petrol.
  Battery warning light/fuse keeps blowing.HELP Clump1298 8 7,019 03-09-2020, 08:21 AM
Last Post: ekjdm14
  Fuel guage stuck on full, but returns to zero with engine off. Will red light work? Charlie0 6 5,075 11-09-2018, 10:11 PM
Last Post: Charlie0
  Brake bad warning light j-n-88 6 4,298 21-12-2014, 05:16 PM
Last Post: j-n-88
