Gear linkage
Having sent my Ph.1 XSi in for one exhaust work, the car now has a slight problem with the gear linkage / gear selection. I know they removed part of the linkage to fit the exhaust so got to work out what's gone back incorrectly.
My question is: the long gearshift selection bar has a cylinder at one end, in to which the large ball from the gearshift control return locates. Should there be a bush or cup in this cylinder that makes the ball locate firmly? On my car, the ball is now a fairly loose fit inside the cylinder and I can't remember what it was like before.
Thanks, Simon
  306 gear linkage bush si_batt 2 2,751 14-06-2017, 06:32 PM
Last Post: si_batt
  Gear linkage Xsikid 9 6,262 22-05-2016, 10:14 PM
Last Post: miles
