Brakes - Brembo questions
Decided to keep the 6 - that said, I managed to pick up a set of Brembo callipers over xmas and thought it was time to fit them (or at least try).
Couple of questions:
Does anyone know the length of brake hose needed?
I know one end is of the hose will be Swivel Male - M10 x 1.00 with a straight fitting angle and the other end will be a Banjo (Thanks Niall) but what size and fitting angle?
Any recommendations for brake fluid?
Thanks Smile
ohhh and yes, I know it's probably going to squeal!
The hoses that Miles sells which you can find on eBay should be fine.
That's what I use on my 330mm setup
Brake fluid dot 4 or 5.1 whichever you want.
(12-03-2016, 06:23 PM)luke306rallye Wrote: The hoses that Miles sells which you can find on eBay should be fine.
Thanks - I've had a quick mooch on ebay but can't seem to find - Do you have a link?
Edit - Found the pugracing web site Smile
Question rs turbo brembo's? shaverspeedengineering 3 2,811 27-03-2014, 06:59 PM
Last Post: Niall
  Brembo Rebuild CJ_Derv 14 8,636 06-01-2013, 10:50 AM
Last Post: CJ_Derv
  V6 Brembo gurj306 9 6,763 14-07-2012, 11:09 PM
Last Post: gurj306
