Threads: 12
Car Model/Spec: Ph-3 Diablo Gti-6
10-03-2016, 02:25 PM
(This post was last modified: 10-03-2016, 02:26 PM by -ER-.)
hi friends;
I will change the location of the battery.
I bought a new cable 50mm like they say it is best for HiFi.
Now the real question is;
Is this the best place to be in the trunk right or left ?
and this cable too thick ?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
can't have a cable thats too thick imoh
as the battery is originally on the passenger side, id run the cable down the same side to the boot in the same side - saves crossing over the car and keeps it simple + if you often ride without a passenger it'll offset your weight for better handling (lol)
but tbh it makes no odds
Threads: 110
20
I just put the battery on my dt in the boot. Mines on the passenger side in the boot.
50mm2 wire will be plenty big enough, i have 25mm2 on mine to start but it wouldn't turn the old diesel over fast enough so i now got 50mm2. Made a huge difference.
