12s yoke passing explanation 8s on xud11ate engine
Hello everybody
and my prepa 205 2.1 td 8s I will explain the passage of 12 s 8 s website or I have helped me full of
pictures but unfortunately as it is encien photos so do her more accessible I'll explain.
for cylinder head passage 8 s better now your have the engine out of the car.
- Good first problem I m realize that the water pump on the 2.1 is not at all the same as the 1.9 endroi it
always possible to leave the pump 2.1 by cutting a tip that gene for the tensioner.
- 2.1 support td doi be changed with that of 1.9 and the tensioner.
(Be sure to place the motor bracket with the idler essailler then after placing the water pump and tips that looked embarrassed and cut)
- The timing belt and a belt 141 teeth 2l hdi
- With the head gasket conserne I rotating with 2.1 td the orifices are the same for the two cylinder heads.
did you not have to machine the 1.9 head? you just bolted it on and it was ok?
Also you used a 2lt hdi timing belt. thats interesting
vous êtes une légende pour cette
(26-02-2016, 07:59 PM)niciou Wrote: Hello everybody
so as previously said did you just bolt the 1.9 head on with no mods to the head?
At the side suport motor distribution after the cylinder head and block should not receive any mod or it must be the
watch if you do not put a turbo deported was the water pump must be careful in the rear as turbo
silk otherwise its not too big touch the water pump if the cylinder head makes it live on the block prepa ultimately quite simple
seriously if you are ever over here i owe you a crate of beer for this!
If anyone can tell me what this guy is saying...I'll buy them a beer! Haha
(26-02-2016, 08:43 PM)bashbarnard Wrote: seriously if you are ever over here i owe you a crate of beer for this!
Thank you this a pleasure to help I pensserai checkout beer when I go up in Anglettre Smile .
after the rub my prepa my turbo td04l is not really suitable for big power that seek me 210
hp turbo this impossible with those more recent past must in addition I have a lot invested in him turbine blade 11
19t 15t compressor pui I have even buy a kit 16g that I have never used my td04l too small for 180 turbo
hp max his will .
hp max his will .
Im not to up with my turbo stuff tbh. if you want simple as in no electronic control a gt2259s should be enough though. spool a little later but whould make over the 200 with correct pump.
below is a link to what vehicles they are found on to help you
http://www.dieselevante.it/turbochargers...am=GT2259S
(26-02-2016, 09:02 PM)Piggy Wrote: If anyone can tell me what this guy is saying...I'll buy them a beer! Hah
I know the translation not great if your not something I compri texplique
hp max his will .
thank you for the info but the spool is how gt2259s without electronic management moin 3000 rev min
was already well remark personally I have a pri electronics but I connai there in case anything so I stay
my late century lol
I have a Bosch pump pump 11 mm.
I pensse that level will have to pump her be well .
Extremely tempted to acquire a 2.1 block now..
  By-passing Heater Matrix HDi Dave 18 14,985 17-04-2012, 03:42 PM
Last Post: Matt
