Threads: 27
1
Car Model/Spec: 205 2.1 8s
Given 2 thank(s) in 2 post(s)
Country:
Hello
Are that someone has already mid larger injector on his XUD9TE engine?
me I have a 2.1 liter engine with low cylinder 1.9 td I have mid dssr performance injector nose but I am not sure that they
give more speed ....
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 32 thank(s) in 32 post(s)
standard injectors are plenty capable for big power
Threads: 591
54
So you have a 2.1 head with a 1.9 block?
The 2.1 and 1.9 share the same injectors...they are good for over 200bhp if in good condition.
Threads: 591
54
Ah ok... Culasse is cylinder head in english.
Hmmm interesting that you have managed to do that... Didnt know it was 100% possible till now..
Why did you go down this route?
Standard 1.9/2.1 injectors are fine for the power you want
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
Want some info on the head bolting up. I've looked into it. Looks like its just the oil way that needs nodding in the 1.9 head. Everything else lines up perfect.
Threads: 371
29
So how did you go about putting the 1.9 head on??
Threads: 371
29
(26-02-2016, 03:28 PM)niciou Wrote: (26-02-2016, 03:25 PM)bashbarnard Wrote: So how did you go about putting the 1.9 head on
je l espliquerai dans mon nouveau post avec les photos du moteur ce soir
I l espliquerai in my new post with motor pictures tonight
a
Ok awesome. My French is limited. But I assume photos tonight with explanation of how.
Threads: 371
29
(26-02-2016, 03:34 PM)Xud Missile Wrote: http://www.maxrevs.co.uk/cars/peugeot/sh...?carId=309
1.9 head on a 2.1 block from 10 years ago ^
Yeah but there is no how to. I'm sure you just have to machine the oil ways together for 1.9 head and use a 1.9 gasket. If I can find out id rather stick a 8v head on mine as it would be easier for parts in futre if I was to kill the precups again.
